liam n Posted December 16, 2010 Report Share Posted December 16, 2010 hi could you help me out i just wanted to know if the echo tr clamps are actually any good and how are they for setting up brakes, i have an onza comp 2010 and was wondering if the flexi frame will change the performance are they worth the £25 ? Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted December 16, 2010 Report Share Posted December 16, 2010 Only if your mounts are flat and square The SL clamps are an absolute godsend, I'd seriously recommend them. They are so easy to set up, the metal washer system is amazing. Quote Link to comment Share on other sites More sharing options...
matt.price Posted December 16, 2010 Report Share Posted December 16, 2010 just set mine up and it saves soo much time Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 16, 2010 Report Share Posted December 16, 2010 Only if your mounts are flat and square The SL clamps are an absolute godsend, I'd seriously recommend them. They are so easy to set up, the metal washer system is amazing. I'm not doubting you, but I don't get how the metal washer would be better? Can you explain Quote Link to comment Share on other sites More sharing options...
court Posted December 16, 2010 Report Share Posted December 16, 2010 I'm running them on mine. Have been since i've had it, no problems at all. If your mounts are slightly out, just file them flat like on this TNN video. Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted December 17, 2010 Report Share Posted December 17, 2010 I'm not doubting you, but I don't get how the metal washer would be better? Can you explain Think he means by 'the metal washer system' that the system is using no metal washer Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted December 17, 2010 Report Share Posted December 17, 2010 Think he means by 'the metal washer system' that the system is using no metal washer Why this kid gotta answer in every topic even when he doesn´t know shit about it? Quote Link to comment Share on other sites More sharing options...
stoozie Posted December 17, 2010 Report Share Posted December 17, 2010 (edited) Think he means by 'the metal washer system' that the system is using no metal washer See here. Now see my sig. Edited December 17, 2010 by stoozie Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted December 17, 2010 Report Share Posted December 17, 2010 See here. Now see my sig. Or, you could actualy take a look at the tr clamps on tarty, and see that they dont need the washer? then, you could look at your link you put in and see it says echo SL. So shut up. Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted December 17, 2010 Report Share Posted December 17, 2010 Or, you could actualy take a look at the tr clamps on tarty, and see that they dont need the washer? then, you could look at your link you put in and see it says echo SL. So shut up. Served. Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted December 17, 2010 Report Share Posted December 17, 2010 Why this kid gotta answer in every topic even when he doesn´t know shit about it? Your the one who is wrong, though. Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted December 17, 2010 Report Share Posted December 17, 2010 Your the one who is wrong, though. Kieran, you complain when people flame you all the time, just wind your neck in a little bit and people might not be so harsh. Quote Link to comment Share on other sites More sharing options...
stoozie Posted December 17, 2010 Report Share Posted December 17, 2010 Only if your mounts are flat and square The SL clamps are an absolute godsend, I'd seriously recommend them. They are so easy to set up, the metal washer system is amazing. Or, you could actualy take a look at the tr clamps on tarty, and see that they dont need the washer? then, you could look at your link you put in and see it says echo SL. So shut up. You could read that again then :'] Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted December 17, 2010 Report Share Posted December 17, 2010 (edited) You could read that again then :'] oops really sorry, have to start reading things twice before i post. Edited December 17, 2010 by Kieran Morrison Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted December 17, 2010 Report Share Posted December 17, 2010 (edited) Edit: Prefer this. Edited December 17, 2010 by xDUNSTANx Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 17, 2010 Report Share Posted December 17, 2010 (edited) Your the one who is wrong, though. plank. Edit: no doubt i'll get warn for that Edit 2: Yeah TR clamps are pretty good ive found, i run them on my lynx, and now front and rear on my limey. proper solid and dont have any trouble with the slave moving in the plastic washer. sound investment they were Edited December 17, 2010 by dirt jumper jake Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 17, 2010 Report Share Posted December 17, 2010 Think he means by 'the metal washer system' that the system is using no metal washer No I think he means the metal washer system! Quote Link to comment Share on other sites More sharing options...
gage-mann Posted December 17, 2010 Report Share Posted December 17, 2010 Echo tr clamps are sweet, i've had them for months, when i first got them i over tightened them so the cylinder did'nt clamp but if that happens it only takes 5 mins to sort it out with a file. Echo sl's are just as good to set up and your mounts dont have to be perfectly square. Quote Link to comment Share on other sites More sharing options...
Adam '93 Posted December 17, 2010 Report Share Posted December 17, 2010 Now see my sig. <3 Quote Link to comment Share on other sites More sharing options...
Sam T Posted December 17, 2010 Report Share Posted December 17, 2010 Not atall advice on Tr clamps, but a mate of mine cracked his SL clamps. Just a lil warning. Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted December 17, 2010 Report Share Posted December 17, 2010 Edit: Prefer this. lol Quote Link to comment Share on other sites More sharing options...
Kieran Morrison Posted December 17, 2010 Report Share Posted December 17, 2010 Edit: Prefer this. Add this one onto the other and your onto a win Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 17, 2010 Report Share Posted December 17, 2010 Add this one onto the other and your onto a win No. Quote Link to comment Share on other sites More sharing options...
SamKidney Posted December 17, 2010 Report Share Posted December 17, 2010 Atomz Elitis TR clamps Work amazing just with maggie plastic clips too. Quote Link to comment Share on other sites More sharing options...
Luke Dunstan Posted December 18, 2010 Report Share Posted December 18, 2010 Atomz Elitis TR clamps Work amazing just with maggie plastic clips too. Actually I'll second that, I had a set of these and they were pretty nice. Quote Link to comment Share on other sites More sharing options...
