Mono Trial Wont Brake?
monty221ti
what do you mean with "cut some thin caliper spacer washers in half to try and take account for any misalignment"?
If you cut some of the thin washers in half to make thin versions of this:
Depending where you put them relative to the caliper and the fork/frame mount you can make the caliper sit at a slight angle to the mount.
so i should use that one instead of a normal shim?
or use it so i can see how many i should put on/remove?
Edited by monty221ti
