fatwomble Posted December 12, 2010 Report Share Posted December 12, 2010 As the title really, I can get an Onza Spyrogyra for £205 (SS) or a Onza Hitman for £225 (Geared). Do I want / need gears when starting out? Quote Link to comment Share on other sites More sharing options...
MiuSliS Posted December 12, 2010 Report Share Posted December 12, 2010 I think if you are looking into buying a bike, you shouldn't just consider gears. Which is probably the least important thing to worry about. Most bikes are SS now, so i guess go for it. In case you decide to change parts you might end purchasing more than planned. To sort of sum up, don't just focus on gears. Look more globaly. Geo, brake set up, weight, whole look/style, only then gears i'd say. Cheers, hope that helps. Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 12, 2010 Report Share Posted December 12, 2010 Remember that at the end of the day if you've got a bike with gears you can always get a single speed kit! Quote Link to comment Share on other sites More sharing options...
onza1 Posted December 13, 2010 Report Share Posted December 13, 2010 [i was also toying with the idea of a cheap stock bike but was unsure< do gears limit you in what you can do on the bike also are single speed kits easy to set up ? Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 13, 2010 Report Share Posted December 13, 2010 [i was also toying with the idea of a cheap stock bike but was unsure< do gears limit you in what you can do on the bike also are single speed kits easy to set up ? No gears don't limit you, as long as at least one of them is the right ratio then there's no problem other than fannying around with shifters and cables. Single speed kits are simple to use, simply remove cassette, slide on spacers and single chainring, set tensioner up and your done! Quote Link to comment Share on other sites More sharing options...
