p_ruskin Posted December 12, 2010 Report Share Posted December 12, 2010 Right, so I tried the search bar numerous times and then realised its sh*t and doesn't give you what your looking for. So I have 2 sealed Hubs both with snapped axles (driveside) and i need to remove them, how would I go about this? I have replacement axles but obviously i cant fit them until i can get the old ones out. Any help would be greatly appreciated. Cheers. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 12, 2010 Report Share Posted December 12, 2010 Remove the end covers if it has any, then tap the axle out using a rubber mallet or a block of wood and a hammer. Then the bearings and axle should drop out. Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted December 12, 2010 Author Report Share Posted December 12, 2010 I have tried using a hammer but it just doesn't seem to move one bit. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 12, 2010 Report Share Posted December 12, 2010 In most cases you really have to hit it IMO. Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted December 12, 2010 Author Report Share Posted December 12, 2010 In most cases you really have to hit it IMO. It just snapped the wood Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 12, 2010 Report Share Posted December 12, 2010 Get some thicker wood! Have you definatley removed the end caps/covers? Quote Link to comment Share on other sites More sharing options...
Greetings Posted December 12, 2010 Report Share Posted December 12, 2010 Pics. Quote Link to comment Share on other sites More sharing options...
LukasMcNeal Posted December 12, 2010 Report Share Posted December 12, 2010 What hub? Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted December 12, 2010 Author Report Share Posted December 12, 2010 Got a new bit of wood and it dropped out after a while hammering, now i have it back in but say the bearings are x wide and the cup in the hub shell is x+3mm to accommodate the bearings and the thickness of the endcap i can only get the bearings right to the edge of the hubshell so the endcap sticks out, any solutions? Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted December 12, 2010 Report Share Posted December 12, 2010 pics will help us massively with this problem, sometimes you have to tap the bearings in a little further on there own i normally use a spanner or socket the exact size of the bearing and hit it in Quote Link to comment Share on other sites More sharing options...
sstein Posted December 12, 2010 Report Share Posted December 12, 2010 Put it in the frame< the frame will force it back in Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted December 12, 2010 Author Report Share Posted December 12, 2010 pics will help us massively with this problem, sometimes you have to tap the bearings in a little further on there own i normally use a spanner or socket the exact size of the bearing and hit it in Thought I'd give your idea a try and if it didn't work get up some pics for you, but thankfully it did work, just needed something the get the bearings all the way into the back of the hubshell, Cheers. Quote Link to comment Share on other sites More sharing options...
