Help! With My Hope Mono Trial
charliet
hello today i bleed my hope mono trial, i had finished it then went to test the brakes but it did not hold. So i bleed it again to check for air in the brake but there still was no air in it but it still did not hold what could be the problm and there is not oil on the disc or pads?
Thanks Charlie
are you putting on the diaphram properly? No matter how well you bleed it you can mess it up by doing this wrong. You need to roll on the diaphram, so no air is caught under neath it and is caught in the reservoir. If there is then it will eventualy or straight away make it spongey.
