Need Help With Balance!
bike_dummie
OK, get on your bike and find a wall, ride straight into the wall as slowly as you can and stop just as your front wheel touches the wall with the handlebars nice and straight.
With a tiny bit of weight on your forward foot you should be able to balance quite comfortably against the wall to get a feel for the perfect balance point.
Breath, breath, breath. When ever i am struggling to balance it is generally because i end up holding my breath. the same applies with power. if i cant get enough height on something not holding my breath really helps. i had to learn to do this by breathing really loud, so practice at home first!!!!!!
  • Like 2
This is excellent advice and always overlooked.
And remember to relax.
This, one generally follows the other, but when you're tense/holding your breath you'll make jerky uncontrolled movements which certainly wont help you to balance. Try and get hold of a copy of tricks and stunts, it's got some really good tips.
If you cant find a wall, do it on a hill (facing uphill) and use your lead foot to control your movement and little breaking :) It helped me all back in the day when bikes had seats :D
Hope this helps.
