Freewheels: Eno Vs. Echo Sl
Theta2
I would and for the following reasons:
The thread isn't quite what it is meant to be.
The engagements are relatively low.
The removal system is just a joke.
The lockring is on the wrong side.
They are not particularly reliable.
Couldn't have put it much better myself really...
I got an eno about a year ago second hand and love it dispite the comments made, but If I was buying a brand new one I would probably go for the SL
The removal system is pretty poor. The last time I did it I had to grind the tabs square with a dremel because they were so mashed up.
Edited by CalopS
I wouldn't say its out of date! It is however overpriced.
It's American.
Besides they can be purchased cheaper than £85. I don't know how anyone can say it has low engagement seeing as 72 is pretty much standard still. You might as well buy an Echo as every person under the moon will tell you to unless they have an Eno of course :giggle:
I've had two ENO's and the lockring has never come lose. So why does it need to be against the crank?
Also, what's wrong with the removal system?
Ride more :P Mine used to come loose pretty often. I tried thread-locking it on and it sort of worked, but it never fully solved it. Then someone borrowed my bike for a while, rode with the lockring hanging off and raped it. Joyous.
The removal system is 'bad' because it sticks out a lot from the body when it doesn't need to, reducing clearance especially if you run a bashring. It's not as good as the new SL style system, or even the old SL/Trialtech/Try-All/V!Z system of recessed tabs.
It's American.
Almost all new freewheels coming out now are 108 click. The Eno used to be ahead of the game when ACS CLAWS were the 'normal' freewheel to use, but those days are gone.
