Heatsink Pads
Rockman
Absolutly amaaaaazing. I used to have a set, lasted from july till a few weeks ago but then they got really low on life. But that was because i got a REALLY sharp grind which just killed them. The hold is truely amazing, and the bite is astonishing. They dont work all the time, somedays the bite will be good, others it wont be so good. But the hold is the same everyday, wet or dry.
COUST SINKS FOR THE WIN
COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS,COUSTSINKS. COUSTSINKS
Rockpads are my only choice, best i have found.
But i would be satisfied with either TNN pads too.
Try-all croca pads, yellow,blue i found alright but nothing special. Rockman i found good but never really had a bite to it but worked well in the wet. tnn kennys i found at first where awesome in dry and wet but then lost all bite/power plus they hate the cold so now trying phatpads and there simply awesome!!! -10 they still had a really good bite and serious hold can't fault them one bit in any condition. waiting on heatsink pads coming, coust and yellows so will be testing these out to see what there like.
Ive had my heatsink yellows for over a year now, about half worn (although I dont get to ride so much these days), running on a medium/light grind and theyre completely reliable, awesome bite and hold in both wet and dry and good wear rate; only down side for me is the stupendous noise :( If your grind dulls too much they lose ALOT of hold but keep the bite, just an easy way to know when your grind needs refreshing ;)
Will definitely be getting some more yellow refills when these finally dissapear.
For reference Im using '97 HS33 slaves, RB lever, water/oil/antifreeze emulsion bled, DX32 with medium/light grind, triton frame with home made 2bolt carbon plate booster - I prefer my brake to have a little squish in it as it stops my tendonitis playing up :)
