Plymouth Trials Posted December 5, 2010 Report Share Posted December 5, 2010 Hey all has anyone got pics of the Rockman Slate 3? CHEERS!!! Quote Link to comment Share on other sites More sharing options...
koxxboy14 Posted December 5, 2010 Report Share Posted December 5, 2010 Hey all has anyone got pics of the Rockman Slate 3? CHEERS!!! Is there even going to be one? Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 5, 2010 Report Share Posted December 5, 2010 There certainly is, I have not seen any pictures yet but I am sure that they will be about soon, there are going to be 2 versions, 1 with a standard headtube and then another version which has a taper headtube, with a 1 1/8th upper headset cup and an 1.5inch lower headset cup, the second version is being sold as a frame set with a headset and pair of forks to match up with the headtube. Adam Quote Link to comment Share on other sites More sharing options...
Plymouth Trials Posted December 5, 2010 Author Report Share Posted December 5, 2010 There certainly is, I have not seen any pictures yet but I am sure that they will be about soon, there are going to be 2 versions, 1 with a standard headtube and then another version which has a taper headtube, with a 1 1/8th upper headset cup and an 1.5inch lower headset cup, the second version is being sold as a frame set with a headset and pair of forks to match up with the headtube. Adam Cheers dude!! Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted December 5, 2010 Report Share Posted December 5, 2010 what are the benefits of having the smaller bottom headset cup and taper forks. i have seen alot of xc bikes / forks with this but never understood why? Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 5, 2010 Report Share Posted December 5, 2010 what are the benefits of having the smaller bottom headset cup and taper forks. i have seen alot of xc bikes / forks with this but never understood why? You mean a larger lower cup, benefits is that the forks can have a larger steerer tube which should make it stronger, also means the headtube is slightly larger meaning a larger weld area with the downtube etc. It will be good to see how well it turns out! Adam Quote Link to comment Share on other sites More sharing options...
Oli P Posted December 5, 2010 Report Share Posted December 5, 2010 (edited) what are the benefits of having the smaller bottom headset cup and taper forks. i have seen alot of xc bikes / forks with this but never understood why? It is larger bottom headset cup, I believe it is just to add strength. Edit: beaten to it. Edited December 5, 2010 by Oli P Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 5, 2010 Report Share Posted December 5, 2010 I don't know if they actually make one, but I just tried to imagine how monumentally huge the lower cup of a taper-headtube FSA Pig would be and almost blacked out. Should be interesting seeing how that turns out though. Part of me's happy that people are branching out, but part of me's not so happy about standardised stuff becoming non-standardised (purely from a 'selling stuff to people' way). Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 5, 2010 Report Share Posted December 5, 2010 I think this is a good idea, I am surprised it's taken this long to get a company to try it, if I could make frame I would have tried it years ago, trials seems the perfect application for a tapered steerer! Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted December 5, 2010 Report Share Posted December 5, 2010 got myself mixed up larger bottom cup, yeah i guess i can see the advantage of it now, not too sure how well it will go down with the trials comunity, maybe its going to be the next big thing. but its allways good to see new things coming to trials such as rockman with this and echo with the spanish BB Quote Link to comment Share on other sites More sharing options...
Greetings Posted December 5, 2010 Report Share Posted December 5, 2010 What's a tapered steerer? Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 5, 2010 Report Share Posted December 5, 2010 What's a tapered steerer? 1 with a standard headtube and then another version which has a taper headtube, with a 1 1/8th upper headset cup and an 1.5inch lower headset cup, the second version is being sold as a frame set with a headset and pair of forks to match up with the headtube. Quote Link to comment Share on other sites More sharing options...
Ali C Posted December 5, 2010 Report Share Posted December 5, 2010 pah, and you call yourself a cyclist! http://lmgtfy.com/?q=tapered+steerertube Quote Link to comment Share on other sites More sharing options...
dirt jumper jake Posted December 5, 2010 Report Share Posted December 5, 2010 What's a tapered steerer? http://fisherbikes.com/images/fisherbikes/tech/roscoe_E2_tech.png Quote Link to comment Share on other sites More sharing options...
Matt Burrows Posted December 5, 2010 Report Share Posted December 5, 2010 another version which has a taper headtube, with a 1 1/8th upper headset cup and an 1.5inch lower headset cup That's awesome news. I'm the same as Ali, I wanted to do this years ago. You only need to look at how thick steerer tubes have become on trials forks to realise the tube diameter isn't big enough! Should be a bit lighter and stronger, tests have shown them to be much stiffer as well. Would be perfect for use with magnesium frames and forks where stiffness is an issue. Quote Link to comment Share on other sites More sharing options...
Chris Elson Posted December 6, 2010 Report Share Posted December 6, 2010 Im glad someone has mentioned the slate 3, iv been waiting for it too come out for a few weeks now. Anyone know ANY more info about them? prices, geo. Hopfully the geo stays the same as the slate 2!!! Quote Link to comment Share on other sites More sharing options...
Bigman Posted December 6, 2010 Report Share Posted December 6, 2010 Im glad someone has mentioned the slate 3, iv been waiting for it too come out for a few weeks now. Anyone know ANY more info about them? prices, geo. Hopfully the geo stays the same as the slate 2!!! As far as I am aware the geo is pretty much the same. Adam Quote Link to comment Share on other sites More sharing options...
craigjames Posted December 6, 2010 Report Share Posted December 6, 2010 Sounds pretty awesome and makes a lot a of sense Quote Link to comment Share on other sites More sharing options...
Jon Alty Posted December 6, 2010 Report Share Posted December 6, 2010 (edited) Get your orders in! http://www.competitivecyclist.com/product-components/2010-chris-king-tapered-nothreadset-6661.272.0.html May be tempted to buy the tapered vesion, however im guessing it will be the more expensive version (more CNC?), and im unsure of how much difference it will make. Edited December 6, 2010 by Jon Alty Quote Link to comment Share on other sites More sharing options...
JamieWilliams Posted December 7, 2010 Report Share Posted December 7, 2010 (edited) Here's a pic of the new slate 3 frame Not sure if you want it Slate 3 You need an account on richmondtrials.com to see it so here's the pic \/ Jamie Edited December 7, 2010 by JamieWilliams Quote Link to comment Share on other sites More sharing options...
MK999 Posted December 7, 2010 Report Share Posted December 7, 2010 I don't know if they actually make one, but I just tried to imagine how monumentally huge the lower cup of a taper-headtube FSA Pig would be and almost blacked out. Not sure if it's sold as a taper but they certainly make a 1.5" version, FSA big fat pig, have one on mine as the mission reefer seems to be the only trials bike in the world to run a 1.5" headset Seem pretty rare but found on here in the US: http://www.pricepoint.com/detail/17313-205_FSABP8-3-parts-63-headsets/FSA-The-Big-Fat-Pig-1.5-Headset.htm Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 7, 2010 Report Share Posted December 7, 2010 Man alive. Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 7, 2010 Report Share Posted December 7, 2010 Mark have you any idea what prices will be like? Will be ordering a new frame and probably forks when you guys return after christmas and at the moment I'm looking at a Born but may swing to one of these as I originally wanted a Slate II! Quote Link to comment Share on other sites More sharing options...
Mark W Posted December 7, 2010 Report Share Posted December 7, 2010 Not too sure atm (all the info's on Adam's computer), but I know we've got both versions of that frame turning up in a week or so. Should be interesting to see them 'in real life'. Quote Link to comment Share on other sites More sharing options...
isitafox Posted December 7, 2010 Report Share Posted December 7, 2010 I look forward to seeing the ones with the forks! Quote Link to comment Share on other sites More sharing options...
