Ben Mortimer Posted December 2, 2010 Report Share Posted December 2, 2010 I have i koxx giacomo coustellier v1 with a eno freewheel on it. It keeps on randomly click really loudly, almost like a cracking crunching sound. But i want a new freewheel any advice on which one. I want it to be as loud as possible and good engagement points. I like the rockman 108 because of the high amount of engagement points 108 and it also has 9 pwals so it will be strong. But any suggestions are welcome. Quote Link to comment Share on other sites More sharing options...
ogre Posted December 2, 2010 Report Share Posted December 2, 2010 open it up, clean it out, re oil it, close it, see if its ok then? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 2, 2010 Report Share Posted December 2, 2010 Eno's are fully servicable so you may as well open it up and see what the problem is first. Sounds like you might have a broken spring or damaged bearing or something. All replacement parts are available though so investigate first. Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted December 2, 2010 Report Share Posted December 2, 2010 Deffo the shell which holds the bearings has retired/cracked. Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted December 2, 2010 Report Share Posted December 2, 2010 Deffo the shell which holds the bearings has retired/cracked. Or not. Either way, investigate! Quote Link to comment Share on other sites More sharing options...
Ben Mortimer Posted December 3, 2010 Author Report Share Posted December 3, 2010 Thanks for the replys but i fancy an upgrade anyway. I just wanted to know what was wrong with it. Quote Link to comment Share on other sites More sharing options...
JT! Posted December 3, 2010 Report Share Posted December 3, 2010 Seems that the Echo SL is the way to go these days. Quote Link to comment Share on other sites More sharing options...
Nick Manning Posted December 3, 2010 Report Share Posted December 3, 2010 Seems that the Echo SL is the way to go these days. I second that. I've had many freewheels over the years. But the best ones I had were: White Industries Eno- Pros Sealed bearings - Cons Lock ring doesn't have enough threads and loosens regularly, tabs to remove freewheel are poor and damage easily. Tryall 108.9 - I can't say I ever had a problem with this freewheel, however I know loads of people did, they seemed to skip a lot. Echo SL- I'm running this currently and had no problems. I specifically like the splines for removing the freewheel, well thought out. Seems to be a popular freewheel at the moment with very few problems heard of. Quote Link to comment Share on other sites More sharing options...
