Onza Blade
Noble biker
hi i was just wondering if anyone else has a 2010 onza blade and what are the good and bad points
I've got an 09 blade, but i've ridden the 2010 blade as well. The good points are; Strong, lightweight frame. Has magura mounts and disc mounts. Bad points; The stem, handlebars and forks are heavy compared to ones you can buy. Overall, the bike is really good.
ok thanks alot i was going to upgrade them any way whats it like to ride ?
  • 2 weeks later...
I went from an old 05 pro to a 2010 onza blade. Nice high bb, disk brake, hs11 rear rim brake. They are great bikes to improve your riding skills on.
Davidbarr is right, steel bars (670ish grams) steel forks (1.3kg) but, it uses an ally stem which is light.
The only other bad points is i've already cracked one of these frames as it doesn't have a built in brake booster (even when running a bolt on brake booster)
They are incredible to ride, buy it, then buy new bars/forks at a later date ^_^
  • Like 2
