Magura Hs33 Repair
SamKidney
with trials, you are often doing stuff that is putting side to side loads on the lever blade rather than just pulling it as it's meant to. After a while it can (and does) crack. If you get another 05+ brake, you can file away the back so there is a smooth transition rather than the sharp edge normally there. This will make the lever last a LOT longer.
the NEW brake is a different design and material, that cover is not a protector as such, more just for looks than anything else.
