Brake Leak... How To Find?
Alex Dark
hey there, got a rear halfords hydraulic disc brake. Only problem is it lsoes pressure in a few minutes of use and the lever pulls into the bar after about a half hour. Are tehre any clever way of finding a leak? Apart from hanging it upside down?
http://washford.scene7.com/is-viewers/flash/genericzoom.swf?serverUrl=/is/image&image=Washford/314401&viewSize=450,507
Turning upside down really won't help! If it's actually leaking you'll be able to see/feel/smell fluid either on the tube or around the fixings or pistons. As said above, sounds more like it's air in the system that needs bleeding out.
  • 1 month later...
