74 Kingz Tensioners
T.McMillan
With more and more frames coming out with either horizontal dropouts or inbuilt tensioning systems, it seems like the potential market for them is shrinking. That said, there are still plenty of vertical dropout frames out there and the 74Kingz tensioners were, as far as I'm concerned, the best solution to the problem. Well, provided you didn't need to take up miles of chain slack, in which case you throw on a Rohloff which I never rated so much.
74Kingz, half a 6" steel rule for a spring, done.
Oh my god, blasphemy of the highest order!
EDIT: Irony? lol
Nah, whenever I've run a 74kingz it's been perfect. No trouble, fit and forget, out the way and lightweight.
Rohloff's on the other hand make it that little bit more awkward to fit/remove wheels, change chains, etc. They're a great product, but I'd take the kingz every time :)
LOVE them! have tried the trialtech with two pulleys and thr trialtech with a roller, have tried spokes and Echo SL tensioners aswell.
Trialtech with pulleys: Suuuper tension, its in the way if you want to remove the wheel, It can take a beating, but it dents your frame if you land on it.
Trialtech with roller: Good tension, its in the way if you want to remove the wheel, if you hit it it will bend and the ride is over...
Spokes: Good, hard to manufacture, chain can fall of if riding rough with some speed
Echo SL: Did not work at all. Not enough tension on the spring
74Kingz: Crappy original spring. i have made a spring out of hacksaw blades. just works, and its easy to take of the wheel when you puncture.
So i have bought 2 extra 74kingz tensioners just to have in the future!
