Forred Posted November 23, 2010 Report Share Posted November 23, 2010 Hi. Just got my first trials bike based on an onza trex. It's got lite guy forks and an onza stem. It's arrived with lots of head set spacers, about 2 inches worth. Do I set the stem at the upper position, ie use all the spacers under the stem? Can you use some above the stem, ie an inch either side? Or do I need to set the stem at it's lowest position and cut the steerer tube? Thanks. Quote Link to comment Share on other sites More sharing options...
Mikee Posted November 23, 2010 Report Share Posted November 23, 2010 Yes you can put spacers above the stem. Have play around with different heights to find what feels best for you. Quote Link to comment Share on other sites More sharing options...
josh32 Posted November 24, 2010 Report Share Posted November 24, 2010 Hi. Just got my first trials bike based on an onza trex. It's got lite guy forks and an onza stem. It's arrived with lots of head set spacers, about 2 inches worth. Do I set the stem at the upper position, ie use all the spacers under the stem? Can you use some above the stem, ie an inch either side? Or do I need to set the stem at it's lowest position and cut the steerer tube? Thanks. set as a upper position helps when jumping Quote Link to comment Share on other sites More sharing options...
