Single Speed Kits
facktrials
I am in the middle of sorting my self out a new rear wheel and hub (pro 2) and was just wandering if there is a particular single speed kit that is better than the others?
I have had a look on Tarty Bikes and they seem to range between £15 and £30. The more expensive one being the Tensile locking kit. Their blurb says "Innovative new 'locking' design helps spread the force put through your sprocket over a wider area, helping to stop your sprocket digging in to your freehub body!" Is this a big problem.
Is it worth paying the extra money for this kit or just go cheap and cheerful?
Thanks in advance
sam
There are few good ones,gusset and dmr single speed kits are good quality, also Tarty Bikes have just the seperate sprockets and spacers for your hub so you can pick your favourite style and weight also you'll need a lockring. Obviously you get what you pay for so go for the best one you can afford.
This would be my list:
Pro-Bolt Allo
Trialtech Carbon
Trialtech Race Splined
Edited by Milo123
