eskimo Posted November 23, 2010 Report Share Posted November 23, 2010 Got some Echo Urban forks on the stock with vee mounts. The previous mode to what is currently available. I want to know what size rim is okay/ what you've used? It's obvious a 20mm Mavic isn't going to be appropriate (damn! cause those are cheap), but i have access (not right now) to a Ryno Lite XL which is 30mm. Reckon i could pull that off? Or should i just buy a new 39mm trial rim? When i say "pull off", i mean work perfect, no bodge jobs, or pads that angle like crazy. Quote Link to comment Share on other sites More sharing options...
Ben John - Hynes Posted November 23, 2010 Report Share Posted November 23, 2010 I have an Atomz lite rim, 35mm I think. And with really low pad life, my vee still sits quite wide. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 23, 2010 Report Share Posted November 23, 2010 It's obvious a 20mm Mavic isn't going to be appropriate Depends what pads you have..? Quote Link to comment Share on other sites More sharing options...
AndrewG Posted November 23, 2010 Report Share Posted November 23, 2010 I have got echo TR rim and it´s ok with heatsink coust pads and were ok with inspired "phat" Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted November 23, 2010 Report Share Posted November 23, 2010 (edited) ryno would be ok with some heatsink pads or other with simmilar backings. Edited November 23, 2010 by ghostrider88 Quote Link to comment Share on other sites More sharing options...
eskimo Posted November 24, 2010 Author Report Share Posted November 24, 2010 Depends what pads you have..? My point follows: ryno would be ok with some heatsink pads or other with simmilar backings. even when the pad has 2mm left you reckons? Looking for something that isn't going to suddenly turn around and be a dick to me. Pad choice, unknown. I have many pads. But i don't know what i'll be using yet. This is a budget build and all i need is rim/spokes. Quote Link to comment Share on other sites More sharing options...
ghostrider88 Posted November 24, 2010 Report Share Posted November 24, 2010 My point follows: even when the pad has 2mm left you reckons? Looking for something that isn't going to suddenly turn around and be a dick to me. Pad choice, unknown. I have many pads. But i don't know what i'll be using yet. This is a budget build and all i need is rim/spokes. Older heatsink backings were so thick,that even with only 2mm of pad they would be as thick as new inspired phat pads I think...so I really wouldn´t be afraid to go for this setup Quote Link to comment Share on other sites More sharing options...
eskimo Posted November 25, 2010 Author Report Share Posted November 25, 2010 Older heatsink backings were so thick,that even with only 2mm of pad they would be as thick as new inspired phat pads I think...so I really wouldn´t be afraid to go for this setup Thanks but pad choice is unknown. I think i'll measure it all up when i get a minute. Quote Link to comment Share on other sites More sharing options...
ogre Posted November 29, 2010 Report Share Posted November 29, 2010 when i had a trialtech in urban forks with a vee with heatsink pads, they were reasonably square, probably had to check the pad angle after a big ride though, a thinner rim is probably better, might be worth holding back on the wheel build and checking the spacing/alignment? Quote Link to comment Share on other sites More sharing options...
