Which Pads
trialsiain
that's why it's a case of trying them all out for yourself with the set up you have.
Heatsinks didn't work too well with a grind imo. But others it worked perfect.
Try them out for yourself :)
Shops should do a "brake pad tester kit" which has 5 or so different compunds eg heatsinky yellows, lgm, phatpads, 2mm of compound of each compound on one pad so you can go through them and see which you prefer :P totally unfeasable but still ha
Edited by dann2707
TNN LGM's or Phat pads. both awesome
On a light grind I personally don't think the lgms are the best choice. They are generally best for med to harsh grinds for wet and dry conditions. I'd recommend the Belaey pads for a light grind for wet and dry conditions. But if you ride alot of wet conditions I'd go for a harsher grind.
Also the Belaey pads are very gentle on grinds we've had rims go for months without a regrind. Bike ridden 2-4 times a week.
