Fixed Stock Hub To Run Snailcams
isitafox
Right ive just sold a few sleepers so can finally order my new wheel but I'm stuck on what hub to use. I'm torn between either a TR modded by tartys or a because, though tartybikes are currently out of the because.
Are there any real pros or cons between the two? It's not desperate as I probably won't be ordering my frame till just after Christmas!
I run the Because hub on my rockman and it is light and has good bearings, I would reccomend this to you. (Y)
