Chain Far Too Close To My Frame....why?
sandeeebeach219
Hey
I have just fitted together my new mod and discovered that the chain is honestly about 2mm from the frame at the chainstay.
I have a trialtech screw on sprocket and an echo sl freewheel on the front. chainline is fine, just dont know why the chain is almost touching the frame :(
Its really hard to get pics so i wont be able to put any up. sorry.
Anyone got any idea?
Cheers
Hey
Cheers
Don´t understand why are you crying if it´s not actually touching it...
It probably will.. lol when theres tension, or lack of tension, it will hit on the frame and rub.
I had the same problem with my echo light.
How i sorted it, was, but putting a washer, next to my snail cam on the inside of the frame, so when u do the bolts up on the rear wheel..the frame is moved out 2-3mm.
Hope this helps?
Hope this helps?
Yeh thats a good idea mate, but wont that make the chainline squint?
