Gaz96 Posted November 21, 2010 Report Share Posted November 21, 2010 I would like to try waterbleeding my brakes in the bath and i have never bled a brake before so would like some help. I havent found any of the videos helpful so a good detailed explanation would be great. Quote Link to comment Share on other sites More sharing options...
krazykid009 Posted November 21, 2010 Report Share Posted November 21, 2010 I would like to try waterbleeding my brakes in the bath and i have never bled a brake before so would like some help. I havent found any of the videos helpful so a good detailed explanation would be great. Used this video to learn from. Big thumbs up Hope I helped James 2 Quote Link to comment Share on other sites More sharing options...
ryan-carey Posted November 21, 2010 Report Share Posted November 21, 2010 This has really confused me? Does this mean that the brakes are using water instead of hydraulic fluid? Quote Link to comment Share on other sites More sharing options...
Jake Beach Posted November 21, 2010 Report Share Posted November 21, 2010 (edited) Used this video to learn from. Big thumbs up Hope I helped James Used that video when I did mine, really good one to use This has really confused me? Does this mean that the brakes are using water instead of hydraulic fluid? Yup Edited November 21, 2010 by Jake Beach Quote Link to comment Share on other sites More sharing options...
krazykid009 Posted November 21, 2010 Report Share Posted November 21, 2010 HS33s can be bled with water or mineral oil. Water gives a more responsive action, but mineral oil needs less regular bleeding and overall maintenance. I personally use a water bleed, but it's personal preference to be honest mate. Hope I helped James Quote Link to comment Share on other sites More sharing options...
ryan-carey Posted November 22, 2010 Report Share Posted November 22, 2010 HS33s can be bled with water or mineral oil. Water gives a more responsive action, but mineral oil needs less regular bleeding and overall maintenance. I personally use a water bleed, but it's personal preference to be honest mate. Hope I helped James Oh right, is it just these brakes that you can water bleed then? Not any hydraulic brakes. Quote Link to comment Share on other sites More sharing options...
Topsy Posted November 29, 2010 Report Share Posted November 29, 2010 (edited) So, I came to the conclusion that I'd like to give a chance to water (pretty fed up with oil actually) and only wanted to ask if I have to lube some parts of the brake etc. And if there are any important things I shouldn't forget whilst/before bleeding. Also, Is destilled or tap water better? We have quite a lot of chalk here. Last question: How much antifreeze should go in? 70%water 30% antifreeze? Thanks Edited November 29, 2010 by Hopping_Topsy Quote Link to comment Share on other sites More sharing options...
Revolver Posted November 29, 2010 Report Share Posted November 29, 2010 50% water 50% antifreeze. Really you should syringe bleed for antifreeze, it's a waste to pour that into your sink. You can use distilled water if you feel happier using it. Quote Link to comment Share on other sites More sharing options...
Topsy Posted November 29, 2010 Report Share Posted November 29, 2010 (edited) Don't have a syringe (Atleast not that i know of), and I guess my mom anyway wouldn't let me pour antifreeze into the sink. lol So I'll probably go for a bucket. Anyway, if i would have a syringe I wouldn't know how to bleed my brake with it. Never done one before. Edited November 29, 2010 by Hopping_Topsy Quote Link to comment Share on other sites More sharing options...
Topsy Posted November 29, 2010 Report Share Posted November 29, 2010 (edited) Just remembered something. The anti freeze won't mess my brakes colour up if I bathe the whole thing, will it? Sorry for the double :/ Edited November 29, 2010 by Hopping_Topsy Quote Link to comment Share on other sites More sharing options...
charlie.rush48 Posted November 30, 2010 Report Share Posted November 30, 2010 Just remembered something. The anti freeze won't mess my brakes colour up if I bathe the whole thing, will it? Sorry for the double :/ I bath bled my brake for the first time for the winter, 50:50 ratio of anti freeze and water,and im never going back to oil(personal preferance) water bled brakes are good if you like a quick lever, were as you will find with oil, it takes a slight bit longer for the lever to go back after pulling it, and it wont change the color of your brake at all hope i helped. Quote Link to comment Share on other sites More sharing options...
