Front Freewheel With Bash Setup
l33th3tr33
So basically I've got some try-all cranks, try-all freewheel and a czar bash. Would there be enough threads for the freewheel after the bash (and presumably a spacer is needed) Is on the cranks? I don't want to have the freewheel hanging on a few threads.
if they are the 160 or 165mm versions then you cant run a bash and a freewheel, if they are 170 or 175 then you should be fine
