Matt Vandart Posted November 18, 2010 Report Share Posted November 18, 2010 Hope pro 2 trials hub and snail cams, does it work? Quote Link to comment Share on other sites More sharing options...
craigjames Posted November 18, 2010 Report Share Posted November 18, 2010 Not unless you've got a frame you put the cams on the outside of the dropouts, you'd need to drill them out obviously and you might want longer bolts to support the axle fully. Quote Link to comment Share on other sites More sharing options...
Mikee Posted November 18, 2010 Report Share Posted November 18, 2010 I'm sure I have seen one with only one snail cam on the drive side (I will try and find the pic). And I have seen it done with the snail cams on the outside of the frame. But can't you only do that on some frames? Quote Link to comment Share on other sites More sharing options...
Revolver Posted November 18, 2010 Report Share Posted November 18, 2010 I've got mine on cams, one on each side. They go on the outside. Quote Link to comment Share on other sites More sharing options...
Muel Posted November 18, 2010 Report Share Posted November 18, 2010 Not unless you've got a frame you put the cams on the outside of the dropouts, you'd need to drill them out obviously and you might want longer bolts to support the axle fully. Don't all snail cams have a 10mm hole anyway? Quote Link to comment Share on other sites More sharing options...
pashley-phil Posted November 18, 2010 Report Share Posted November 18, 2010 (edited) I'm running my snail cams on the inside with a pro 2 trials hub works fine for me Edited November 18, 2010 by pashley-phil Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted November 18, 2010 Author Report Share Posted November 18, 2010 All good answers! Ta very much. Quote Link to comment Share on other sites More sharing options...
welsh_side_2003 Posted November 18, 2010 Report Share Posted November 18, 2010 some snail cams are 10mm, 12mm, 15mm. Quote Link to comment Share on other sites More sharing options...
