Stefkeeee Posted November 16, 2010 Report Share Posted November 16, 2010 (edited) The frame came in last friday but I didn't had the time to build it up until yesterday. Uploaded with ImageShack.us Uploaded with ImageShack.us Uploaded with ImageShack.us Spec: -Try all stem long -Monty 221 pr bars -Trialtech foam grips -Try all headset -Onza rip fork -Front wheel: monty single wall rim+monty disc hub, try all sticky tyre -Rear wheel: echo tr disc rim+echo tr hub, try all sticky rear -KMC heavy duty BMX -Echo tr sprocket -Monty freewheel -Tubes: front monty rear: kenda 19" massive inner tube. -Trialtech cranks -Monty cage pedals -Brakes: front Magura marta rear: hs33 2010 rockman blue cnc The bike weights about 9.2kg which isn't to heavy if you ask me. Thank you tarty for the fast delivery. Cheers Edited November 16, 2010 by Stefkeeee Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted November 16, 2010 Report Share Posted November 16, 2010 Looks ace dude, really wish mine would have lasted a bit longer, Amazing frames! Quote Link to comment Share on other sites More sharing options...
