Echo Sl Tensioner On Try All Hub
super
There's the SL (made for 12mm axles) and the TR (made for 10mm axles) - they're both variations of that product.
In related news, I don't think it'd work, even with a lot of bodging. H hubs are pretty wide, so I think it'd be tight. If you compare the two, the drive-side axle spacer on the TR is mahoosive.
Very good point, i'm thinking of making a much narrower centre section that slides onto the axle(i work in an engineering company so shouoldn't be a problem) but still not sure if it can be thin enough and still mount the spring.
