Super Glue For Pad-Backing?
Greetings
So long as the pads are reasonably tight Super Glue is fine. If they're not a tight fit, you'd be safer with Araldite.
Although if the pads & backings are at the correct tolerances (few other than ours are, I've found), they won't need any glue at all, which makes taking them in and out so much easier.
