Hope Piston Magnets Or Springs
EnnBee
Does anyone know where i can find some magnets that are usually found holding the pads to the piston on hope mono trial brakes. I bought one second hand and someone has removed them so the pads are constantly rubbing. Any help would be great. Cheers Neil
Edited by EnnBee
They don't use magnets, they have a small spring between the pads. If you have that already and they are still rubbing then it could be anything from; caliper not aligned, pads worn at angles, siezed pistons, worn caliper piston seals, fork disc mount not faced correctly, too much fluid in the the system or a sticky master piston seal.
Im not sure where to get the magnets, but they do appear to use magnets Tartybikes.
Jed
they do use magnets ive had 3 brakes.
Jed
Whoops my bad, I stand corrected. I highly doubt you will be able to buy just the magnets on their own though. Maybe a good opportunity to replace the pistons and seals, or just send it off to Hope and let them service it for you.
Help. Anyone?
Unless you want to try and bodge some magnets to fit and glue them into place then you will have to buy some new pistons.
