Hench Cracking Noise, No Skip.
Azarathal
Everything is tight, well greased, runs smoothly e.g. no grinding in the bearings.
I've blown BB bearings before, and just spinning the cranks didn't make anything happen, but every now and again (when I was putting load through it), the broken bits of bearing would get momentarily stuck between the correct balls then pop through, making a 'crack' noise. Only way I could tell was by taking the cranks off and spinning the spindle by hand. Even then it was hard to tell the difference from when they were broken and when they weren't.
  • Like 1
This^
If its definitely not the BB then check the freewheel bearings and the frame for any cracks.
Mark's right about the BB bearings because my Echo BB is doing the same. If your off the bike and spins the cranks back you won't hear anything, but if you trackstand on the bike and pedal the cranks backwards slowly then you should hear the cracking noise with each turn of the cranks.
