Hope Tech X2
l33th3tr33
I wouldn't recommend one for trials. They are pretty poor on power and bite, but have plenty of modulation
So, if it's not really the best brake......
Tech lever on a Mono Trial caliper on the other hand... :shifty:
Then why (on assumption that you're saying a tech lever on a mono trial caliper makes a beast of a brake) does the tech lever produce a better brake?
Wasn't the Tech X2 the replacement for the Mono Mini? As in a XC brake? Hope make a trials specific brake why would you try one of there others that are intended for other disciplines?
Just having a browse on the site and there's a 'meter' type thing on the side of the screen and half (off the top of my head) of the trials meter was full. So, just wondering if anyone has used one.
Edited by l33th3tr33
not the best brake for trials? or not the best brake all together? They are one of the best made brakes and up there with the best for trials, but the caliper piston is too small to produce the power needed for trials.
The X2 lever has a lot of adjustment and doesn't develop any wobble, power is the same as a mini lever, but you can dial the feel more. Combined with a Mono Trials caliper gives plenty of power and good feel.
