kustom-trials Posted November 9, 2010 Report Share Posted November 9, 2010 Hello, just wondering what people think is better and whether its worth grinding a rim or just buying rim tar from somewear (: Cheers Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 9, 2010 Report Share Posted November 9, 2010 grind, works in the wet Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted November 9, 2010 Report Share Posted November 9, 2010 Depends, if you don't ride in the wet then tar. Otherwise grind, but you'll have to bear in mind a rim can only take a certain amount of grinds. Quote Link to comment Share on other sites More sharing options...
mattyd1 Posted November 9, 2010 Report Share Posted November 9, 2010 I won't not grind like sed above it weakens the rim a big amount Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 9, 2010 Report Share Posted November 9, 2010 I won't not grind like sed above it weakens the rim a big amount not true Quote Link to comment Share on other sites More sharing options...
Ben John - Hynes Posted November 9, 2010 Report Share Posted November 9, 2010 I won't not grind like sed above it weakens the rim a big amount Nope. Not true in the slightest. Quote Link to comment Share on other sites More sharing options...
Jon Alty Posted November 9, 2010 Report Share Posted November 9, 2010 (edited) Logically, if you think about stopping quickly, then making the rims rougher (grinding) is evidently going to be a greater advantage than tar, as tar just makes the rims (and everything else) sticky, which is not the main principle behind braking. To brake successfully you need 2 rough surfaces to rub against one another, therefore causing friction, which will stop you. Having 2 sticky surfaces will also stop, you but not aswell, because there isnt as much friction, as a stick substance is almost like a liquid. To your comment about a grind weakening the rim, that is not true. The rim will be the same strength in the vertical plane (which is what you want in a rim, and even horizontally, taking a few mm off the rim is not going to do much at all. Trust me, tar is a bitch and gets everywhere, but your choice. That is my opinion anyway. Edited November 9, 2010 by Jon Alty Quote Link to comment Share on other sites More sharing options...
konstant Posted November 9, 2010 Report Share Posted November 9, 2010 Logically, if you think about stopping quickly, then making the rims rougher (grinding) is evidently going to be a greater advantage than tar, as tar just makes the rims (and everything else) sticky, which is not the main principle behind braking. To brake successfully you need 2 rough surfaces to rub against one another, therefore causing friction, which will stop you. Having 2 sticky surfaces will also stop, you but not aswell, because there isnt as much friction, as a stick substance is almost like a liquid. To your comment about a grind weakening the rim, that is not true. The rim will be the same strength in the vertical plane (which is what you want in a rim, and even horizontally, taking a few mm off the rim is not going to do much at all. Trust me, tar is a bitch and gets everywhere, but your choice. That is my opinion anyway. Well that's an interesting take on physics. Tar is ok, but needs applying regularly or braking becomes worse than with a clean, smooth rim. Grinds last for ages. There'a always the Dremel option if you're scared of angle grinders or in a rush to go riding in the rain. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted November 9, 2010 Report Share Posted November 9, 2010 Dremel option? o.O Quote Link to comment Share on other sites More sharing options...
l33th3tr33 Posted November 10, 2010 Report Share Posted November 10, 2010 Dremel option? o.O Let me know how long it takes. Use a grinder. Quote Link to comment Share on other sites More sharing options...
Azarathal Posted November 10, 2010 Report Share Posted November 10, 2010 You obviously weren't paying attention to the post above me. He mentioned a dremel option and I'd never heard of it before, hence the question mark and the o.O Quote Link to comment Share on other sites More sharing options...
Old School Swindon James Posted November 27, 2010 Report Share Posted November 27, 2010 A harsh grind everytime accept if you ride lots of manual street stuff and want smoother style then use smooth rim and appropriate pads. Grind works all of the time and the pleasing noise let's you know your breaks are working just fine, the noise is also good for alerting others of your presence!! It's finding your favourite pads that's hardest. Most trials retailers will grind a rim if you don't want to go to work with the angle grinder...... As Ali C said you can trust it in the wet, which gives confidence in conditions such as the current weather. Quote Link to comment Share on other sites More sharing options...
N.Wood Posted November 27, 2010 Report Share Posted November 27, 2010 Logically, if you think about stopping quickly, then making the rims rougher (grinding) is evidently going to be a greater advantage than tar, as tar just makes the rims (and everything else) sticky, which is not the main principle behind braking. To brake successfully you need 2 rough surfaces to rub against one another, therefore causing friction, which will stop you. Having 2 sticky surfaces will also stop, you but not aswell, because there isnt as much friction, as a stick substance is almost like a liquid. Please dont listen to any of this. Quote Link to comment Share on other sites More sharing options...
pogo Posted November 27, 2010 Report Share Posted November 27, 2010 It's all about the pad and rim combo as well as frame flex. Not just grind or tar. Quote Link to comment Share on other sites More sharing options...
StarkeyS2K Posted November 28, 2010 Report Share Posted November 28, 2010 We used to use tar off the roads back in the day when we were younger, doesn't last very long though! I think a good Rim/Pad combo is better which is what people have already said obviously if you had coloured rims you wouldnt really want to grind them! Quote Link to comment Share on other sites More sharing options...
Kheridr Posted November 30, 2010 Report Share Posted November 30, 2010 depends on your setup, i.e frame flex and etc if your running cable breaks maybe upgrade to hydraulic, cause cables tend to stretch and lose tension, though this is expensive and for quick fix replace cables but to your question use grind Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 30, 2010 Report Share Posted November 30, 2010 depends on your setup, i.e frame flex and etc if your running cable breaks maybe upgrade to hydraulic, cause cables tend to stretch and lose tension, though this is expensive and for quick fix replace cables but to your question use grind cables come pre-streched and don't noticeably stretch in use. Besides, it's not hard to put a tad more tension on the arms (if it's a vee brake), one of the many advantages they have over hydraulic systems Quote Link to comment Share on other sites More sharing options...
Mark W Posted November 30, 2010 Report Share Posted November 30, 2010 Tar belongs on a roof, on a road or in a smoker's lungs - not on your rim. Grinds just feel way, way better. A lot more predictable (I always found with tar it was a fine line between "This isn't doing anything" and "Oh shit, my brake didn't let go...", not to mention the lack of any form of modulation), they perform better in the wet and they don't have to be reapplied as frequently. Quote Link to comment Share on other sites More sharing options...
dannytrialskid Posted November 30, 2010 Report Share Posted November 30, 2010 Tar belongs on a roof, on a road or in a smoker's lungs - not on your rim. Quote Link to comment Share on other sites More sharing options...
KurtiisBrookhouse Posted December 2, 2010 Report Share Posted December 2, 2010 I ride grind and tar with TNNs and my brake works amazing. Kurtis Quote Link to comment Share on other sites More sharing options...
pogo Posted December 4, 2010 Report Share Posted December 4, 2010 I ride grind and tar with TNNs and my brake works amazing. Kurtis I did the same it it didn't. Luck of the draw. Quote Link to comment Share on other sites More sharing options...
Robin M S/c Posted December 5, 2010 Report Share Posted December 5, 2010 Grind is the way to go. Tar needs redoing regular, no good in the wet, too much and the pads stick. Its just not consistent. Yes eventually grinding will mean a new rim but Adams has done a full season of grinds and still going strong. Quote Link to comment Share on other sites More sharing options...
Ben John - Hynes Posted December 6, 2010 Report Share Posted December 6, 2010 I ride grind and tar with TNNs and my brake works amazing. Kurtis That makes NO sense. Why not just give it a better grind? And not use shitty tar that makes your brake crap in the wet. Quote Link to comment Share on other sites More sharing options...
dann2707 Posted December 6, 2010 Report Share Posted December 6, 2010 should generally be one or the other man. But from my experience tar is shite compared to decent pads and a nice grind. Quote Link to comment Share on other sites More sharing options...
chris4stars Posted December 7, 2010 Report Share Posted December 7, 2010 put it this way, what do the majority of the worlds top riders use if they are running a rim brake? Quote Link to comment Share on other sites More sharing options...
