Crank Loose
mr.tattoo
right almost every ride or 2 rides my drive side crank arm comes loose, ive tried locktight but still does it after a bit, the splines on bb dont look worn niether does the crank arm, is this common due to force aplied on that side arm, or is there minimal wear on the crank arm causing this to wor loose? when nipped up its rock solid, no play etc. cheerz guys
