Freewheel Stuck On Rear Wheel
l33th3tr33
Hey guys, basically I've got a rear wheel with a freewheel that needs removing, but I don't have access to a tool yet. Is there any way I can get it off without damaging the hub?
I think theres a good video guide on tarty bikes on how to do it with a chain and vice.
I got my mates off without the tool, got a screwdriver and a hammer, twatted the outer ring off with the screwdriver, put the inner ring in the vice, wound it up tight then just spun the wheel off :)
Bit of a bodge but cheaper than a tool if you're a tight arse haha
You can eliminate smashing the f**k out of the outer ring if you take the lockring off and just slide the teeth off the body if it's a cheap one prepare to have bearings and springs flying at you though :P
I was thinking this, but wasn't too sure. I'll see what's what tomorrow and give it a bash, quite literally.
