Echo Sl Freewheel Help
3dd
I have a Echo SL freewheel that I have been using for about 6 months. Freewheel never skipped, although when I took it of to put it on new cranks noticed that it makes loose bearing noise when shaked. So I though I would get a new freewheel, got a trial-tech one, but it seemes to be skipping at very annoying times, so I though i would find out what is up with SL. Echo SL is also not as smooth as t-tech one when you spin it by hand, could that mean the bearings are gone or needs greasing? Never took a freewheel apart as well so not too sure! Is the lock ring welded on to prevent it from loosening by itself?
Thanks in advance!
