Dušan Posted November 3, 2010 Report Share Posted November 3, 2010 Hey huys i have a dumb question but how do i remove bearings from my hub?i think it has a closed bearings.... not sure what is a exact name for that bearings looks similliar to this echo (just an example most of them are simmiliar) Quote Link to comment Share on other sites More sharing options...
trials owns Posted November 3, 2010 Report Share Posted November 3, 2010 if its sealed then i dont think you can? Quote Link to comment Share on other sites More sharing options...
Dušan Posted November 3, 2010 Author Report Share Posted November 3, 2010 well....not so sure... ... how do i lube them then? by removing the dust protection? Quote Link to comment Share on other sites More sharing options...
Hessy Posted November 3, 2010 Report Share Posted November 3, 2010 Yes, you should be able to. This is how I did it: 1) Get a block of wood (so you don't damage the axle) and place it on the axle. 2) Hit the block of wood with a hammer. 3) One bearing should come out with the axle. 4) Take the bearing off the axle and put the axle back in the hub. 5) Hit the axle from the opposite side so the other bearing pops out with the axle. For putting the bearings back in: 1) Place a bearing on the hub where the bearing goes. 2) Tap the bearing back in making sure it is going in square. 3) Place the axle in the hub. 4) Put the other bearing in using a socket (slightly smaller than the outside diameter of the bearing, but still touching the outer metal part of the bearing) to slide over the axle, again making sure it goes in square. Hope this helps Any questions fire away!! Quote Link to comment Share on other sites More sharing options...
Dušan Posted November 3, 2010 Author Report Share Posted November 3, 2010 thanks alot gonna do it tomorrow as i have my hub in the garage Quote Link to comment Share on other sites More sharing options...
Ali C Posted November 3, 2010 Report Share Posted November 3, 2010 Yes, you should be able to. This is how I did it: 1) Get a block of wood (so you don't damage the axle) and place it on the axle. 2) Hit the block of wood with a hammer. 3) One bearing should come out with the axle. 4) Take the bearing off the axle and put the axle back in the hub. 5) Hit the axle from the opposite side so the other bearing pops out with the axle. For putting the bearings back in: 1) Place a bearing on the hub where the bearing goes. 2) Tap the bearing back in making sure it is going in square. 3) Place the axle in the hub. 4) Put the other bearing in using a socket (slightly smaller than the outside diameter of the bearing, but still touching the outer metal part of the bearing) to slide over the axle, again making sure it goes in square. Hope this helps Any questions fire away!! Yep, do this Quote Link to comment Share on other sites More sharing options...
