chris170483 Posted November 1, 2010 Report Share Posted November 1, 2010 hi all just wanting to know its ok to put a disc brake on the rear wheel no a 26inch trials bike??? i would go for a hs33 but the frame cant take hs33's just disc or v-brake Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted November 1, 2010 Report Share Posted November 1, 2010 If the frame is made to take a disc, surely that means it's fine to put a disc on it? Quote Link to comment Share on other sites More sharing options...
Onza Kid Posted November 1, 2010 Report Share Posted November 1, 2010 (edited) discs on a 26inch are ok but they flex too much but if they are made for a disk shorly they have fixed the problem to the best of there ability and should be ok i would recomend a maggie though Edited November 1, 2010 by Onza Kid Quote Link to comment Share on other sites More sharing options...
Mark W Posted November 1, 2010 Report Share Posted November 1, 2010 Sort of - it's not hard to just put a generic disc mount on a frame, but it's not easy to make a frame strong enough to take a disc. A nicely set up V will probably feel better than a disc on a 26" bike. Flex in the wheel makes discs on the back of 26" bikes feel a bit 'weird'. Quote Link to comment Share on other sites More sharing options...
chris170483 Posted November 1, 2010 Author Report Share Posted November 1, 2010 ok thanks mate, a few people have told me that, do u think i would be able to get a hs33 mount put on the back of the frame??? thanks Quote Link to comment Share on other sites More sharing options...
MagnusT Posted November 1, 2010 Report Share Posted November 1, 2010 ok thanks mate, a few people have told me that, do u think i would be able to get a hs33 mount put on the back of the frame??? thanks If you choose to use disc make sure to get a powerful brake and a big rotor, I have a jump bike with 24" wheels and giant brakes the rotors are 160mm and they are way too weak for trials riding!! Quote Link to comment Share on other sites More sharing options...
Mark W Posted November 1, 2010 Report Share Posted November 1, 2010 ok thanks mate, a few people have told me that, do u think i would be able to get a hs33 mount put on the back of the frame??? thanks If it's an aluminium frame, then if you do it won't last long. Seriously - just try and get a decent V-brake setup on there, they can be really good! SD7 levers are pretty awesome and cost about £11, a set of calipers shouldn't be much, cables are pretty cheap, get some decent V-pads on there and you should be good to go. Quote Link to comment Share on other sites More sharing options...
