ogre Posted October 30, 2010 Report Share Posted October 30, 2010 my pro2 has started to skip, i think it needs a servicing, i know i don't use grease i should use oil, i've got some fenwicks all conditions chain oil, will that be alright? its not thick. photo's please Quote Link to comment Share on other sites More sharing options...
Matt Vandart Posted October 31, 2010 Report Share Posted October 31, 2010 If its a new one dude its easy. Click I There is a fidio somewhere also. Quote Link to comment Share on other sites More sharing options...
Simpson Posted October 31, 2010 Report Share Posted October 31, 2010 Just pull it apart see what it looks like, mine looked HORRIBLE, loads of shit and gunk - you can just give it a quick wipe and put it back if you leave some of the old grease on there. Quote Link to comment Share on other sites More sharing options...
Ben John - Hynes Posted October 31, 2010 Report Share Posted October 31, 2010 (edited) It's seriously easy man! The driveshell just pulls off("just", ha). Get a tool with some long handles like so: place the handles underneath your sprocket and just lever the whole thing off. The pawls and springs will then be accessible, take them out(a spring may well be broken if it's skipping) and arrange them on your desk/work surface in the pattern they came out. Give the ratchet a clean up and what not, clean the springs and the pawls, obviously order a new spring from HERE if you need to. Then putting it back together is the reverse of taking it apart really. Job done. Edited October 31, 2010 by Ben John - Hynes Quote Link to comment Share on other sites More sharing options...
ogre Posted October 31, 2010 Author Report Share Posted October 31, 2010 do i need to remove the circlip that sits inside the freehub body>? Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted October 31, 2010 Report Share Posted October 31, 2010 (edited) http://m.youtube.com/index?desktop_uri=%2F&gl=GB#/watch?xl=xl_blazer&v=fdgUvv76H28 That tells you everything you need, to be fair though I just run mine dry it's louder and gives a more solid engagement IMO if you bend the springs up slightly aswell itl put more pressure on the pawl and cause it too engage faster and prevent skipping Edited October 31, 2010 by WIGAN ?? Quote Link to comment Share on other sites More sharing options...
Ben John - Hynes Posted October 31, 2010 Report Share Posted October 31, 2010 do i need to remove the circlip that sits inside the freehub body>? What circlip? Got a pic? There should be a washer at the end of the axle which just slides on/off. Quote Link to comment Share on other sites More sharing options...
ogre Posted October 31, 2010 Author Report Share Posted October 31, 2010 took the wheel to je james, they pulled the end cap out with a vice and everything popped out hunky dory after thoroughly cleaned the internals, and put some light oil in, sounds excellent Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 31, 2010 Report Share Posted October 31, 2010 I was going to mention about the endcap earlier but didn't get a chance to - too late now, but hey ho, haha. As soon as that's off it's super easy Know for next time now I guess Quote Link to comment Share on other sites More sharing options...
