crashbanggg Posted October 28, 2010 Report Share Posted October 28, 2010 I brought some cranks/ freewheel and fitted them earlier. However because the new freewheel has less teeth my chain tugs obviously have to be further back along the dropout than they were before. This then means my rear brake (HS33) is on the tyre and it cant be moved down in the clamps at all. I know the obvious way to fix this is to remove some links but I wanted to make sure there isn't a quick fix before I start taking to bits?? Quote Link to comment Share on other sites More sharing options...
Phatmike Posted October 28, 2010 Report Share Posted October 28, 2010 If you can, removing links is the quick fix. Quote Link to comment Share on other sites More sharing options...
