michaelweeks24 Posted October 27, 2010 Report Share Posted October 27, 2010 hi there i,m new to this site and not sre how this thing works but basically i have problem with my chain tension or possibly my freehub everytime a put load on the pedals it feels like the chain slips i,m running a 74 kingz tensoiner and tried a different tensioner which only made itworse so i put the 74 back on the freehub body is on a hope pro2 so i,m hoping the freehub body is fine and its is just the chain tension what can with out taking the free hub body apart to find the fault i dont mind taking it part but i,d rather leave it as a last resort Quote Link to comment Share on other sites More sharing options...
Endohopper Posted October 27, 2010 Report Share Posted October 27, 2010 Hmmm , difficult to diagnose but given that differing tensioners affect the "slipping " I suspect you're not getting sufficient chain wrap on the rear cog . What size cog are you running ? You might get reliable results with a sprung tensioner like this . Might be worth inspecting the chainline aswell to ensure it's running in as straight a line as possible between front and rear chainrings / sprockets . Welcome to the forum by the way , you already have a validation vote from me for this post . Quote Link to comment Share on other sites More sharing options...
WIGAN ?? Posted October 27, 2010 Report Share Posted October 27, 2010 Ok is it a clunking like the chain slipping off the sprockets or is it a smooth movement ?? If it's your chain skipping then read that guys post ^^, if it's just a slow smooth movement on the cranks then either the treads on your hubshell or cranks have stripped, if it's your hub your ok cause hope will replace the shell for free Quote Link to comment Share on other sites More sharing options...
michaelweeks24 Posted October 28, 2010 Author Report Share Posted October 28, 2010 Hmmm , difficult to diagnose but given that differing tensioners affect the "slipping " I suspect you're not getting sufficient chain wrap on the rear cog . What size cog are you running ? You might get reliable results with a sprung tensioner like this . Might be worth inspecting the chainline aswell to ensure it's running in as straight a line as possible between front and rear chainrings / sprockets . Welcome to the forum by the way , you already have a validation vote from me for this post . thank for the welcome bro and mega helpful advice i will look into it now knowing where to start top man and thank you dude .M. Ok is it a clunking like the chain slipping off the sprockets or is it a smooth movement ?? If it's your chain skipping then read that guys post ^^, if it's just a slow smooth movement on the cranks then either the treads on your hubshell or cranks have stripped, if it's your hub your ok cause hope will replace the shell for free its like a hard clunking skip and for a brief second it feels like the cranks have no chain attached but it only happens on hard pedalling it never happens in slow movement Quote Link to comment Share on other sites More sharing options...
dann2707 Posted October 28, 2010 Report Share Posted October 28, 2010 I can't help you on said topic. However I've given you a validation vote. Hope that helps mate Quote Link to comment Share on other sites More sharing options...
michaelweeks24 Posted October 28, 2010 Author Report Share Posted October 28, 2010 I can't help you on said topic. However I've given you a validation vote. Hope that helps mate cheers buddy whats is this validation thing i,m new lol Quote Link to comment Share on other sites More sharing options...
michaelweeks24 Posted October 28, 2010 Author Report Share Posted October 28, 2010 (edited) Hmmm , difficult to diagnose but given that differing tensioners affect the "slipping " I suspect you're not getting sufficient chain wrap on the rear cog . What size cog are you running ? You might get reliable results with a sprung tensioner like this . Might be worth inspecting the chainline aswell to ensure it's running in as straight a line as possible between front and rear chainrings / sprockets . Welcome to the forum by the way , you already have a validation vote from me for this post . i,ll get BACK TO YOU ON HE COG SIZE BRO Edited October 28, 2010 by michaelweeks24 Quote Link to comment Share on other sites More sharing options...
