Spoke Tensioners.
alex-trials-boy
Easiest way is to get the longest spoke you can (I used to use 268mm spokes and they were about right), then using a hammer and vice bend the spoke just after the threaded section 90°. With your wheel in the frame put that end of the spoke through your bolt for your mech hanger (so it goes from inside the frame pointing out), then put a nipple on it to keep it in place. Then you just have to wrap the spoke anti-clockwise around the hub axle as tight as you can, then once you've got a couple of coils around the hub axle just use a pair of pliars to put a gentle 'S' shape in the spoke to get it to sit nicely on the middle of the chain. Put a little upward kink on the tip of it so it doesn't stick into the chain and you're good to go.
As I said, that's the easiest way of going about doing it. There are other ways that are a bit nicer in the long-term, but if you're just starting with them that's probably the best way (Y)
Thanks mark :)
"bolt for your mech hanger (so it goes from inside the frame pointing out), then put a nipple on it to keep it in place."
that bit confused me what bolt?? can you show me a pic?
Is it for your Inspired? If so, your mech hanger bolts onto your frame - the bolt it uses is hollow, so just run it through that.
That's about right, yeah (Y)
Spoke length depends on hub, sprocket size, etc. - mine were on either a Pro 2 T or a King (so quite a large axle to cover), and with larger sprockets which meant I needed more spoke. If you've got a 15t or under sprocket I would've thought it would be fine.
They are really tricky to make iv tried loads of times to get it right but just can't :S and I don't really trust them to be fair thers nothing really stopping the chain just bending off the spoke then your f**ked, I know people who run them and are confident with them will argue different but that's just me
If you make it right, there's no reason it would do that? Your chain's going in a straight line, the spoke should be sitting in the little dip between the side plates - there's nothing to make it move sideways anywhere. Ran spoke tensioners for the past 9 months, haven't had it happen once...
I know what your saying but I think it's just a phycological thing that thers just that little bit of steel keeping my teeth in, I'd rather use a nice sturdy tensioner with jockey wheels
usually your chain can't jump off anyway, unless it's mega slack, then a spoke tensioner probably isn't up the job, it doesn't take away masses of slack chain it just keeps a chain thats the right tension tighter ;)
