Try-All Shift Front Tyre, Tread Direction?
hugh_b
Have been building my bike this evening. When it came to fitting the try-all shift front tyre their doesn't seem to be a specified tread direction as there is with the rear! From pics i've noticed the giacomo coustellier running it the same way as me and gilles running it the other way. Is it a case of run it what way you think is right or is there an intended direction which works the best? I currently have mine with the white logo's on the drive side!
Hugh
It'll most likely depend on what kind of surface you're riding on as to which way you prefer. Looking at the shape of the tread blocks the 'normal' way to run it would be with the TryAll logo facing left (angled blocks indicating a rolling direction). Though I know I run my rear minion the 'wrong' way to try and aid traction on loose ground.
Edited by Gibbon on an Orange 2
