22 Tooth Chainring On 104Mm Cranks
vladamtb
Hi people, I`m having a Truvativ Holzfeller Cranks 104mm 2009 model with single 36 tooth chainring, my question is it possible to have a chainring with 22 tooth for 104mm cranks, and who makes such. I found a Truvativ Holzfeller Trials Cranks with 22 tooth but i don`t want to buy a new cranks just a chainring if it`s possible. Thank You.
It is possible to have a 22t chainring on those cranks providing it has the 4 smaller holes inside the spider. The bash ring would go on the 4 larger spaced holes where your current chainring is and the 22t ring would go on the smaller spaced holes in the middle if that makes sense. As far as I'm aware the 104mm is the spacing between the chainring mounting holes.
Hope this helps
