Chain Skipping All New Parts
Dan Jones
Hi, I'm running 20t middleburn hardcote chainring, 17t Gusset bachelor rear cog and Trialtech Z610 HX 3/32
chain. Under load the chain rides up on the rear cog. All these parts are new. I'm using a Kingz tensioner.
I have tried:
Using a Surly cog and the problem is much worse
Some grease on the Gusset cog which has improved things.
Taking out as many links as possible from the chain.
Does anyone know if this will improve as it wears or if another rear sprocket would be better to use?
Thanks for any help.
Edited by Dan Jones
I had chain skipping problems, changed most of the parts, ended up with a new tensioner (dual jockey wheel sprung types) which sorted it, must have been the chain wrap even though I assumed there was plenty.
