Water Bleed
tdubz
planning on doing a water bleed tonight
got my brake second hand and im convinced there is oil in it
willl the water and oil mix in the hoses/cyclinders or shall i just keep flushing with loads of water until it sorts itself so to speak
many thanks
I flushed it untill it was clean when i did mine. Also remeber to mix the water with anti freeze or some vodka to stop it freezing in the cold weather coming up. :)
Ashes.
what kinda ratios we talking here?
thanks
Something like 3 part water, 2 part anti-freeze/ Vodka. (Y)
A rear HS33 generally only really holds around 25ml or so in it, so the ratios aren't really that important. It's only going to differ by a couple of ml either way which isn't really going to do too much.
