Cundog123 Posted October 16, 2010 Report Share Posted October 16, 2010 hi, i have a problem with my back maggy because my pads are set up square and very close to the rim but my lever pulls in nearly touching the bar and it doesn't hold, any ideas of what to do. thanks matt. Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 16, 2010 Report Share Posted October 16, 2010 Bleed. At least sounds very much like you need to do so. If you watch your pads and pull your lever, do the pads move as soon as you squeeze the lever a bit? If they don't, you need a bleed. Quote Link to comment Share on other sites More sharing options...
trials owns Posted October 16, 2010 Report Share Posted October 16, 2010 (edited) bleed the brake! as air is likely to be it there, either that or you have a leak somewhere. EDIT ha i got beaten to it. Edited October 16, 2010 by trials owns Quote Link to comment Share on other sites More sharing options...
t-comp-kierz Posted October 16, 2010 Report Share Posted October 16, 2010 hi, i have a problem with my back maggy because my pads are set up square and very close to the rim but my lever pulls in nearly touching the bar and it doesn't hold, any ideas of what to do. thanks matt. Have you tried adjusting the tpa? Quote Link to comment Share on other sites More sharing options...
Cundog123 Posted October 16, 2010 Author Report Share Posted October 16, 2010 when i pull in the lever the pads start coming in when the lever nearly hits the bar but the thing is, its only just had a fresh bleed Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 16, 2010 Report Share Posted October 16, 2010 Sounds like it hasn't had a very good bleed then The pads should literally move as soon as the lever itself starts moving, otherwise there's air in the system. Quote Link to comment Share on other sites More sharing options...
Cundog123 Posted October 16, 2010 Author Report Share Posted October 16, 2010 i think i will give it a rebleed, thanks for the replies guys Quote Link to comment Share on other sites More sharing options...
Ashes Posted October 16, 2010 Report Share Posted October 16, 2010 I'll come to yours tommorow if you like cunny haha, because we all know how good my bleeds are. Ashes. Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 16, 2010 Report Share Posted October 16, 2010 Could try the top-up bleed trick - if you get a bleed hose and syringe with some of your brake fluid in (oil, water, whatever), then attach that to the bleed port on your lever. If you give the lever a bit of a squeeze, you'll see all the air in your brake rush into there. If you keep gently squeezing the lever, it moves all the air up into the bleed hose/syringe and out of your brake. Works pretty well, although it does depend how much air you've got in there. If it's pulling to the bar, might be worth doing a full bleed again... Quote Link to comment Share on other sites More sharing options...
