Drivetrian Problem- Dmr Revolver Hub
murph82
Gutted, gone to put my cranks on (Tensile optimums with uci style guard and 96 click FW) and the BB I had which I thought was ISIS is evidently some dodgy specialised strongarm splined offering specific to those cranks. I now need a BB but dont know what length I will need or how to work it out ?
Its to go on an old koxx levelboss frame, if anyone could advise i'd be grateful.
Also took my acs claw off my rear hub, DMR revolver (flip flop style ) and tried screwing my echo tr sprocket on and it gets about half a turn before geting to tight toturn with my hand, the fw spun on aqnd off is easy, is the sprocket the wrong size? --- can with way to much brute force get it on about 3 threads deep now need to whack in a vice and use the wheel but worried i'm gonna bust something,anyone else had this problem?
Thanks for your help in advance.
kevin
Edited by murph82
I've got the same set up and mine were fine, what size is you thread on the revolver because you can get a small size for 15t on below and a bigger for 16t and above. Clean you threads
got a tr sprocket and presumed its all the same????no real way of lmeasuring though?!?
I know a few people who have stripped the threads on those hubs before just from riding. Could it be that the threads are slightly squished which is making it difficult? If this is the case you can't really do anything anyway but clean them as much as possible and try to fit the new cog. Sometimes running a very sharp and thin knife down the dips in the threads can help to clean them up. You can use it almost like a file to help re-cut flattened parts of threads. Other than that just grease it up plenty, make sure its on the first few threads properly, and if its still tight you might have to just force it on and prey!
