Removing Anodising
Franksx2005
Caustic soda bath will remove anodizing, results may vary though and the aluminium will be a dull grey colour underneath. Thats a lot of caustic soda though, certainly wouldnt want to do it myself!
its to get it powder coated. They said it would need to be bare metal to powder coat it.
Im pretty sure you should be able to powdercoat over anodising, after all its only a coloured oxide layer. Blasting is another option, depending on how much you want to spend though, blasting with shot will possibly affect the material (wearing some away), alternative blasting medias are stuff like vapour and walnut husk which are much gentler on the base material but more expensive. I would speak to the powerdcoaters and check about the anodising.
edit: These people state that anodising is a good preperation treatment for powdercoating, Im sure you must be able to wash it down sufficiently to coat.
Edited by forteh
Thanks for the replys mate. im awaiting there return call as he has gone to find out.
I was about to say that, anodized frames seem to have quite a rough feel (compared to not) and the powder should stick well to it.
Walnut husk eh, who would have thought. Does that get anodizing off?
Would get it shot blasted my self (Y) maybe glass beads? cheap, soft on the material and eco friendly for all who care.
Pretty sure that this is a surface prep before anodizing, either shot blast or chemical etching.
If you look at the Bjorn frame (still cant spell i think :S), the graphics are nice and smooth where as the rest of the frame has the grainy affect your talking about :).
Bit of a pointless post really, but thought id share the knowledge.
Cheers,
Josh.
