Tarty Order Help
J Harris
looking at placing an order for FFW, ive got an 128 skf bottom bracket and looking to run an echo sl 108, but the advice section states you might not be able to run a bashguard with this setup, what basguards can you run with this freewheel and bottom bracket? would a trialtech titanium bash fit with enough threads?
  On 10/12/2010 at 4:30 AM, MadNick1.2 said:
Tartys wont do a warranty either!!
That's only the case if the BB shell hasn't been faced. If it has, Pace/SKF are usually really good with warranties. If someone wants to try and warranty an SKF BB that's snapped because the BB shell wasn't faced we'll do so, but Pace/SKF almost always say no. We don't decide anything on warranty cases, so it's not a case of "Tarty won't do a warranty".
