Electrical Fundamentals
Sam Nichols
Ok I'm completely lost here.
I can deal with series and I can deal with parallel but I'm trying to work out how you get the total resistance, total current and the voltage drops for each resistor on a parallel-series circuit..
Here's what I've got..
Basically I think the total R is 99Ω and the total I is 1.01A. Is this right? If not, how would I get the correct answer.
Also, how on earth do I work out the V-drops?
Many thanks! Hopefully someone on here can help.. :P
Adding resistors in parallel is 1/(1/r1 + 1/r2 + 1/r....) - so on and so forth. Adding resistors in series is as simple as r1 + r2.
Resistors added in parrallel will always give a value lower than the lowest resistor when added together. Break the circuit down into 2 parts.
Parallel = 1/(1/50 + 1/70) = 29.16 ohms (this is now theoretically in series with the other two resistances)
Series 29.16ohms + 30ohms + 40ohms
=99.17ohms.
For future reference, when there are only two resistors in parrallel you can use the equation 'product over sum'. As so - Rt = R1 x R2 / R1 + R2
Edited by Robwalker
v/r(equiv) = (v/r1)+(v/r2)
100/r(equiv) = 100/50 + 100/70
100/r(equiv) = 2 + 1.43
100/r(equiv) = 3.43
100 = 3.43r(equiv)
29.15 = the resistance over the parallel section. Then add 40 and 30 to get 99.15 total Resistance.
The voltage drops over parallel resistors are the same no matter what the resistor values are. So replace the parallel section with the 29.15 (round it up to 30). Seing as though the total resistance adds up to 100 and the voltage is 100 the voltage drops over the 30ohm resistor is 30v, and 40v over the 40ohm resistor. Both the resistors on the parallel section both have a v drop of 30v
Thanks guys, I get it now! Todays lecturer was pretty crap so I struggled to grasp it!
Rob, I'm training to be an aircraft engineer, doing some early modules at the moment (all really basic stuff). Nailed the maths and physics but I've never done electronics before.
Thanks for the voltage drop explanation too, JT.
advanced apprenticeship with e.on, looking to specialise in control and instrumentation. Im half way through my national certificate, then onto my foundation degree. If i do well enough at that e.on pay for me to go and complete my full degree at uni. result.
Engineer or Technician? Are you designing or repairing? Electronics is about following some fundamental rules - learn the basic rules and you'll be able get yourself round almost any issue (voltage and current laws). I'm assuming all aircraft systems are DC so that simplifies the electrical calcultions (AC power factor, lead, lag etc.).
  On 10/18/2010 at 4:30 PM, nichols_sam said:
I'm doing a combined course. A degree in aeronautical engineering (design) and a B1 aircraft maintenance licence.
So all going well at the end of the course I can choose either.
Cool, having worked in engineering for years (R&D and design, though I do a totally different job now), it seemed to be, heavy electrical side anyway, the maintenance technicians that seemed to get the better pay working as contractors than the actual engineers. Not sure how it is in the aeronautical arena but worth looking into/considering when the time comes to decide. My first degree was in electrical and electronic engineering (also trained as an electriician whilst doing my PhD - C&G 2330) - any electrical questions feel free to PM me.
Dr. Tim (BEng, PhD)
That's not always the case although most do run from rectified AC. The airframe will supply a 115V (nominal) AC supply for use by all the on-board electronics. Using Ohms law and other calculations comes a lot easier with time and practice. Try not to get too bogged down with the maths though. On a day-to-day basis you won't be using much more than a few simple formula's. It is more important to understand how and why they are used.
Dave (Electronics Engineer - Aerospace)
Edited by David
