tdubz Posted October 11, 2010 Report Share Posted October 11, 2010 ive just started building up my new gu frame put the cranks on and two problems: 1. the chainring does not spin because it is too close to the chainstay 2. without the chainring on the top of the crank arm clips the tube which the brake is mounted to i run truvative husslefelt cranks with a 22t ring and bash im relucatant to change my cranks and also my chainring size so i am hoping maybe somebody could recommend mabe a bottom bracket alternative which will solve the problem thanks Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted October 11, 2010 Report Share Posted October 11, 2010 ive just started building up my new gu frame put the cranks on and two problems: 1. the chainring does not spin because it is too close to the chainstay 2. without the chainring on the top of the crank arm clips the tube which the brake is mounted to i run truvative husslefelt cranks with a 22t ring and bash im relucatant to change my cranks and also my chainring size so i am hoping maybe somebody could recommend mabe a bottom bracket alternative which will solve the problem thanks How do, maybe look at a longer BB? What size have you got in atm? Cheers, Josh. Quote Link to comment Share on other sites More sharing options...
tdubz Posted October 11, 2010 Author Report Share Posted October 11, 2010 not sure what length to be honest what is a suitable length thanks Quote Link to comment Share on other sites More sharing options...
Jamie_Trials Posted October 11, 2010 Report Share Posted October 11, 2010 Need a 128mm really, 127.5 will do though Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted October 11, 2010 Report Share Posted October 11, 2010 Without your chainring (im sorry im not sure what one of these is) you can use a spacer in there. Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 11, 2010 Report Share Posted October 11, 2010 not sure what length to be honest Then measure it what is a suitable length Longer than your answer to the previous bit But seriously, you're probably going to struggle to get that setup to work... Quote Link to comment Share on other sites More sharing options...
tdubz Posted October 11, 2010 Author Report Share Posted October 11, 2010 Then measure it Longer than your answer to the previous bit But seriously, you're probably going to struggle to get that setup to work... maybe another set of cranks with a smaller chainring might be the only solution then Then measure it Longer than your answer to the previous bit But seriously, you're probably going to struggle to get that setup to work... but this guy seems to be running a simlar set up http://i847.photobucket.com/albums/ab32/mrmad4uk69/ac7d38fe.jpg Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 11, 2010 Report Share Posted October 11, 2010 Is that the same frame you've got? I thought you meant the 'new' new GU frame... Quote Link to comment Share on other sites More sharing options...
tdubz Posted October 11, 2010 Author Report Share Posted October 11, 2010 Is that the same frame you've got? I thought you meant the 'new' new GU frame... sorry mark mate im not being very helpful am i haha its new to me but its actually second hand its this frame here http://www.trials-forum.co.uk/index.php?app=core&module=attach§ion=attach&attach_rel_module=post&attach_id=44406 thanks mate Quote Link to comment Share on other sites More sharing options...
tdubz Posted October 12, 2010 Author Report Share Posted October 12, 2010 update ive measured the bb its 113mm worth buying a 128 mm one and see if that solves my problems? Quote Link to comment Share on other sites More sharing options...
Rob Leech Posted October 12, 2010 Report Share Posted October 12, 2010 update ive measured the bb its 113mm worth buying a 128 mm one and see if that solves my problems? Go for it, should sort it out . Josh. Quote Link to comment Share on other sites More sharing options...
