Second Frame Build- Seventh And Final Update For A While
Rob Leech
  On 11/23/2010 at 5:47 PM, craigjames said:
How much does a reasonable TIG set up go for, I've got a 3 phase socket in the garage for the MIG plant so that's OK and have some basic experience; just fancy a bit of a play...
If your looking for AC/DC, you can probably get a decent second hand one for 400-500, which is about a quarter of the price you'd pay for a good ally mig, lol.
Just have a look on ebay, or try and find a local welding supplier, they normally have second hand plants knocking around (Y).
Cheers matey,
Josh.
Oh, can you get hold of gas easily enough? Not too easy to find places to get it on the sly now-a-days.
Looking tidy - I think I'm almost as excited to see this finished as you are haha!
To take the thread backwards slightly - can someone clarify the benefits of open-ended vs closed gussets to me please? Not entirely sure which is best for certain applications/why, so an explanation would be cool if anyone would be so kind (Y)
Would also like to know this, always seen open ended as a bit of a weak point?
Josh.
I remember reading somewhere ages back that open-ended allows stresses to 'escape' the gusseted region more freely, but since so many manufacturers use different approaches I'm unsure of whether this applies to every situation. If anyone fancies shedding light...
In the meantime I'm going to hunt around the net and see what I can dig up
looking good, I like the chainstay area.
I am going to go back to gussets though. You welded them up completely, is there a reason? It was my understanding they were working best when left open ended and welding them completely can create a stress riser?
Yh, the chainstay bit is my favorite bit of the frame.
Iv'e welded the gussets fully because i've seen alot of frames crack where the weld normally ends. It seems that it only takes a small defect in the weld at this point (normally whats called a 'crater crack') to make it crack quite easily.
Im not exactly practiced in the whole stress analysis thing, but to me, leaving the gusset open would only put more stress on the weld at the two points where it ends?
Not too sure about it if im honest, going on my own experiences, sort of experimenting, will probably leave the gussets open on the next one, see if there's any difference when they're both ride-able.
Cheers,
Josh.
  On 11/25/2010 at 10:55 PM, dirt jumper jake said:
Like a spot weld setting?
EDIT: or as in pulse transfer?
Pulse transfer, it raises and lowers the voltage very quickly like, which sort of imitates AC characteristics when welding.
I wouldnt go near MIG for welding up any frame, wether it be ally or steel, stick with TIG (Y).
Cheers,
Josh.
However, they are very usefull for when your tacking it all up :P.
Edited by Rob Leech
Cheers,
Josh.
Aye i get you, im still learning at college you see :P & wish i could afford a TIG, got a beasty Oxford MIG at home for doing stuff on my jeeps n that. we've got a small snap-on (cebora) 160 MIG at work, pretty good for its size actually. what would you recomend TIG wise? ive heard good things about Esab & Murex, but thats probably cos there the same company haha.
Ritey o, fair do's with the oxford, mighty things :P.
Cant really help you on choice, only ever used parweld and lorch, wich are both pretty much the same, apart from the lorch comes up with error codes every 2-3 weeks (N).
But most of our stuff is parweld and never have any problems with them :).
Cheers matey,
Josh.
Oh, update in 2 seconds nd all.
Cheers matey,
Josh.
Ah my lid is parweld :P cheers man will check them two out :)
Edit: looks mighty nice built up man, nice one (Y)
Edited by dirt jumper jake
  On 11/27/2010 at 7:02 PM, Luke Rainbird said:
Looks sick dude, I want one! :wub:
Massive props, you've done a really good job of it.
Anything you'd do different next time/have you learnt much through the process?
Cheers matey, im pretty happy with it atm.
Yh, bits nd bobs, mainly to do with the angles that the tubes were bent to and the gusseting really.
This one took alot longer, but has gone so much smoother than the last, having a decent jig to assemble it in helps so much, lol.
Cheers,
Josh.
Cheers,
Josh.
The failure of the skull, if only ONZA had left off the bash mount this frame would a have been a million times better.
I believe the gussets are left open for torsional stress reasons specific to round tubes.
If you look here:
Neon have welded across the end of the gusset as this is not a round tube it will not effect it so much.
Or something
OOPS!
Edit: what I meant to say was..........That frame looks loverly well dode dude i am loving it!! (Y)
Edited by Matt Vandart
Ritey o, fair do's.
I still dont really see a problem with it, my baby pitbull's gussets are welded all the way round and that is probably one of the strongest frames around (seeing as it has lasted nearly 7 years and has been through a long line of riders).
I have just seen so many frames crack/snap at this point after a good smack to the downtube, don't really want this to happen to mine :P.
Dont wana argue about it really, it'll be different on the next frames (Y).
Cheers,
Josh.
